69 Mach 1 351W close ratio Toploader
My trans is grinding 1st to 2nd unless I’m gentle. Supposedly rebuilt under previous ownership not too many miles ago.
I found plenty of sludge on the drain plug when changing the oil recently. also worth noting that the clutch linkage was a mess causing reduced travel. Fixed now.
Is it likely I’ll need just blocker rings or a synchro assembly and gears too?
