I have read a lot about timing and I have a decent understanding of initial timing. The purpose is to have the spark plug fire BTDC at the proper time for proper combustion of the air fuel mixture. Stock engines I have read can be 6-8-10 degrees BTDC. Later model engines I read like 16 degrees or so (mine is at 15 degrees). Too late and fuel is not completely burned which can result in poor performance, overheating, etc. Then there is mechanical advance which is rpm driven with weights and springs. The two together = total timing.
The desired range of total timing is typically 32-36 degrees.
Initial timing: from what I understand one way to determine the proper amount for your engine is to slowly keep advancing until you hear pinging (pre-detonation) under load and the back it off a little until the pinging goes away. I can do that. As for total timing, I don't hear specifics about how to determine what is proper for each engine. What is read is: "my engine likes 34 degrees total timing". My problem is my engine doesn't talk to me and tell me if it is happy. So how do I know what is the best total timing for my engine?
I would love some education.
