Hey Guys
as per my last post I have decided to to a custom suspension following closely what this guy did on his falcon but with different control arms, and using the stock mounts for the uca and lca.
http://forums.vintage-mustang.com/attachment.php?attachmentid=31841&d=1249922355
but using these control arms
http://www.howeracing.com/p-7792-blue-max-precision-a-frame.aspx
Howe Racing Enterprises - Strut Style Style A
I want to do the shelby drop on the uca but I have read you can go lower with the mounts but the ball joint will bind I was thinking of ordering the uca with the 7 degree ball joint mount to compensate for this. How low should the mount hole be for best handling?
Also since I already have my rims which are 18/9 bullitts with 6 7/16" bs I was thinking of ordering the control arms longer than the stock by 1" or 1.5" to compensate for the spacer needed to use these rims. Anyone see any problem with this? I will be doing a home brew rack swap and the extra width opens up the selection of racks to use.
the rest of the suspension will be stock spindles and discs, with adjustable strut rods and a coil over shock conversion
thanks in advance
thanks in advance
