I have 2 cylinders (#1 and #3) that have been getting a lot of oil dumped in them. This fouls out 2 of the plugs in about 5 miles of driving. The other cylinders do not foul out. I have checked for signs of a bad head gasket and see none.
This is a 1967 mustang with a stock 200 six. Compression is 180 to 190 on all cylinders. I just did a full tune up and rebuilt the carburetor. The problem is definitely oil related. I can see oil in the cylinders if I look in there with a flash light. The other cylinders are dry. Crazy part is the car does not smoke at all that I can tell. Do not know how to explain that!
Car has roughly 25 to 30,000 miles on a rebuild that was done quite a while ago (15 years). The car is a my weekend fun cruiser so does not get a ton of miles each year.
Hoped I would find bad valve seals but they look fine. Maybe a bit less flexible than new but they do remain pretty flexible and have no rips or missing pieces.
Using the rope trick I pulled the valve spring of off my #1 intake valve (plug fouls out on #1). The valve is tight up to the head and being held up by the rope. I can rock it back and forth pretty good. Not a ton but enough to hear a tick tick sound as it hits the sides. How much is to much? I don't mind pulling the head and having new guides put in if that is what it takes to fix it. Obviously don't want to do that if some rocking of valve stem in the guide is normal. Should it move back and forth at all?
I would like to post a video of it rocking to get opinions on if it is bad or not. I plan to take a video with my iPhone. How do I go about posting a video? I am familiar with posting pictures and can do that no problem.
Thanks much for any advice / help!
