Finally finished my tranny updates last night and fired up it!!! No drips, no leaks, no runs!!! I addressed all 4 of the major C4 leak areas:
Tranny Pan - upgraded to a Trick Flow deep pan. It has thick cast aluminum flanges all around and 1" thick bolt bosses. It also has a drain plug!!!
Dipstick - that dang O-ring was cracked, and the dipstick was kinda chewed up on the end - nothing a new chrome set wouldn't solve /forums/images/icons/wink.gif
Cooling lines - what a mess!!! I had 65-style lines, which use hoses at the radiator end of both lines. In addition, both lines had been "patched" twice each, and the rear fitting in the case (the 90* one) was cracked and leaking. I used 66-style lines which are solid from front to rear with NO rubber hoses.
Seals - replaced the shift-shaft seal and rear seal.
It was all a PITA, as I had to drop the tranny mount, front crossmember, idler arm, disconnect the e-brake, and the exhaust just to get the lines out/in, but well worth it. I had a hard time finding the rear fitting, but a local place called "A & Red's Automatic Transmission Parts" finally had it- for all of $2.00!!!
Now, on to the other upgrades.........../forums/images/icons/wink.gif
http://a5.cpimg.com/image/3B/A7/8980795-d573-0190012C-.jpg
