The size is 1/2 x 50. You will also need "off-set" washers which center the wheel onto the stud if the wheel bolt patten is "universal" size, which is likely with the S/S model.
Cragar makes several SS wheels. Which ones are you getting? If you are ordering the wheels and lugs from the same place, call and ask.
Some use conical seat lugs, 0.800" long shank, 0.500" shank mag lugs and offset washer mag lugs.
http://www.cragar.com/ProductSearch.aspx?c=15
Look up your wheel and size or part # and it'll show what kind to use.
Back in the day...there was only Cragar SS lug nuts. you couldn't go wrong.
