1 - 13 of 13 Posts
jackro
· Registered
Discussion starter · #1 ·
Everybody sells these SFE 20 as 1-1/4" long. TOO LONG even Pony parts' are too long.
My 67 has a 1-1/16" position for it. Anybody know where I can get these?
The CIG LIGHTER/EMERG FLASHER position in the fuse box is listed by Ford as using an SFE-20, which is 1-1/4" long. An AGX-20 is an inch long which should work if the SFE-20's are too long.
I just bought some AGX 20A ( package of 5) glass tube fuses made by Littlefuse at Oriely's Auto parts store for under $5. These are 1" inch long and will fit into the fuse box for the (cigarette/emergency flasher) slot. All the other 20A fuses are too long and don't fit. Get them while you can and always keep a stock pile for any emergency.
i get em at lowes. not cheap any more. used to be 99 cent a box now like $6
but then again gas was 59 cents when i was starting in this hobby :)
worst case senario is just get fuse taps and a universal inline holder so you bypass the fuse box terminals and can use any size glass fuse you can find
1 - 13 of 13 Posts
