So other than outlet differences...the radiators are the same?
I am running a thermal clutch
With the thermal spring on the front, right?
, shroud and 7 blade fan. I don’t want to go the dual electric fan route unless I HAVE to.
Probably would not be an upgrade from a properly-working 7 blade BB fan.
I could not fit my 100 amp Taurus alternator on the 390, and had to go back with factory 60 amp. Its not really up to par for contour fans or others? Still chasing my tail.
It does not boil over, per say, but will puke a small amount when shut down and in heat soak.
If the radiator is too full, this is actually normal.
It also drags the starter pretty heavily when its shut down after a run to get gas or a drive down highway. I’ve backed timing down to 6*, factory spec. Underhood temps are down, but the air cleaner and carb are almost too hot to touch.
Normal in a BB.
My gas percolates and makes for hard starts.
Also normal now that it's polluted with ethanol.
It’s a Summit 750, and I’ve added a 1/2 phenolic spacer as well.
Good carb, good choice of spacer.
No headers, 428 exhaust manifold, Edelbrock performer 390 intake. The exhaust passage under carb is NOT blocked off. I think this is the problem of too hot carb. I have bought more take gaskets, and may go back into it and block those exhaust passages that go from head to head through the intake/ carb base. Thoughts?
The 69 Mustang 390GT engine had a water-cooled carb spacer. Although I think it was mainly intended to prevent carb icing, I can't help wonder if it would also prevent the carb getting too hot.
