289 crank but won't start
4.4K views 14 replies 7 participants last post by  ufobobo
Hi. Washed my car with high pressure water (**** me) and after that my car died. It is an electrical problem. The starter cranks but the engine won't start. Tried to pull out a spark plug and there is not spark so I think It is the coil or the ignition switch. Is there a trick I can use to try to start the car?
Thank you and **** me again
a) Check to see that you didn't knock the lead off the coil+ post with your pressure washing.
b) Check to see that you didn't knock the lead off the solenoid "I" post with your pressure washing.
c) Check to see that you didn't force a bunch of moisture inside your distributor cap with your pressure washing.
