how much better flowing is the 351W head compared to the 302 head? I want to spice up my engine but dont want to waste a bunch of money if it really isnt worth it. Thanks!!!
got website?gotstang said:Only the intake ports are different from 289/302/5.0 heads, and they're only about 10-15% better flowing anyway, probably 15hp difference. Stock for stock, its not worth it. Why not a set of ported 302 heads from Thumper? $500 shipped completely assembled with high performance parts and probably a good 30hp
www.thumperoforangepark.com69stroker said:got website?gotstang said:Only the intake ports are different from 289/302/5.0 heads, and they're only about 10-15% better flowing anyway, probably 15hp difference. Stock for stock, its not worth it. Why not a set of ported 302 heads from Thumper? $500 shipped completely assembled with high performance parts and probably a good 30hp
Are you kidding?...Have you looked at various exhaust ports over the years?..Non of them are very big but at least some are wide open..Others have big thermactor bumps and pipes stuck in them..I have a set of 68 J-code heads that came with a smog pump and you can't even stick your pinky finger through the exhaust port its so congested..gotstang said:Only the intake ports are different from 289/302/5.0 heads, and they're only about 10-15% better flowing anyway, probably 15hp difference.
I have a set of 69 351W heads I was planning to use on a 289 build but after talking to my engine builder he explained that if I use those heads I'll have to go with higher compression pistons to make up for the compression loss with the larger chamber size in the 351 heads. Unless I have to replace the pistons anyhow for an overbore I'm just going to stick with the 289 heads and do a basic rebuild.buening said:New GT-40 heads have the same size valves as the old 351w heads and flow slightly better. Combustion chamber size is different though, so it depends on your pistons to ensure you don't end up with too low/high of compression ratio with a head swap. Not as easy as just randomly picking a head and putting it on the motor.
Mill those heads about .030 and you'll get your compression back. Piston to valve clearance will be less if that is a concern, but you can check that easy enough. Intake manifold will have to be milled too.doug ford said:I have a set of 69 351W heads I was planning to use on a 289 build but after talking to my engine builder he explained that if I use those heads I'll have to go with higher compression pistons to make up for the compression loss with the larger chamber size in the 351 heads. Unless I have to replace the pistons anyhow for an overbore I'm just going to stick with the 289 heads and do a basic rebuild.
You're still not necessarily comparing apples to apples, though. The '68 289 heads and all but the J code 302 heads have 60.4 or larger combustion chambers.buening said:Yeah the 289 heads have a cc of 54.5 while the 351w heads have 60.4 You'd get a definite drop in compression going to the windsor heads unless you do a piston change.
