Hi, I'm currently rebuild the '69 302 engine.
The engine block and crankshaft are in the mechanical shop.
I don't have any doubts about assembling the bottom of the engine, but I have a few questions about the parts for the top of the engine.
The engine will be use for:
Now I need to think about parts for the top of the engine (like heads and camshaft).
Currently I have E7 heads, I don't have camshaft (I have only hydr flat tappet set M-6500-B303)
I was thinking about changing to a roller cam, but it costs about $800-1000, and I think I will choose the flat cam and I'd rather use the money to change E7 heads to alloy heads.
What camshaft do you recommend for the application I described?
I would like to replace the head because the factory ones require porting and planning to increase compression (I would like to achieve 9-9.5: 1) I will check which heads will be suitable for this level of compression, and the aluminum ones will additionally improve cooling
- put into a 1970 Ford Capri
- manual gearbox T5 - I have a T5 from 2.3 (I will deal with its adaptation to the engine)
- daily driving, sometimes maybe a little faster
- RPM range - I would like it to be higher than the factory one - up to about 5500-6000
- smooth idle speed - I don't like "chop sound"
- good reaction to throttle
- at the beginning I will probably use a carburetor but I will also want to be able to use EFi (like Edelbrock Pro-Flo 4 EFI or custom 8 x throttle body and efi controller with MAP sensor, without MAS sensor)
