Been reading all the posts on running temps, overheating issues, etc and wanted more opinions on the running temps of the 351W. The car starts right up and runs great but I have been obsessing about the running temp.
Newly resto moded 66 coupe with a rebuilt 351W with a mid range cam. Based on the block number I believe it's a 1979 block. Two row aluminum radiator, 2500 cfm puller fan that covers 90% of the radiator turns on when radiator gets to around 160. 180 t-stat, water wetter, 20% coolant, distilled water. New electronic gauge set from new vintage.
About three miles into a 40 mph drive after start up. Temp gauge gets around 195 and then drops down to 180. It then slowly moves between 190 and 200 and finally remains between 195 and 200. I'm in Nothern CA and the weather hasn't been exceeding hot.
Should I be obsessing about it? Is this an acceptable temp for a '79 351? I've had both a 192 and a 195 t-stat in it and temp ran betwen 200 and 210 with those, usually more towards the 210.
