If you don’t have adjustable rockers arms like my Cleveland 351 2v ….do you simply torque down the rocker arm bolts to the proper spec and that’s it?? I think so but asking everyone who knows to confirm..
This ^^^^No.
a. The camshaft must be on the base circle for the valve being tightened.
b. The bolt is tightened to "zero lash".
c. The bolt is then SLOWLY tightened to 20 lb./ft., counting the rotation of the head. If it takes less than 1/4 turn of the bolt to reach 20 lb./ft., you need longer pushrods. If it takes more than 1 full turn to reach 20 lb./ft. than you need to shim the pedestal. Since the rocker bolts are 5/16-18 you can calculate 1 turn of the bolt to equal .05555" and a hex nut having six sides means one wrench flat of movement equals .00925" to determine the extra pushrod length or shim thickness needed.
im by far not a mechanic. Im mechanically inclined and follow instructions to the letterOkay.. to me it doesn’t make sense that anything other than tightening down the rockers here for non adjustable arms works.. there’s a bolt, a square spacer/washer that seats the rocker arm on the blocks rocker mount and that’s it …no adjustment no locking nut etc.., I don’t see the point of turning the crank to insure open close etc..unless the lifters loaded and won’t allow you to tighten the rocker bolt down but I’m not seeing that.. . it’s a seated rocker mounted into a fixed mount without any adjustments, and that’s it. Bolt down that’s it me.. I don’t see any way you can damage anything or
Need to do more.. by just Torquing each bolt down to 25 foot pounds each ??? So anyone…. give me the logic here otherwise…
I take that claim with a grain of salt. On the "assembly line", the engines were already assembled, painted and run. I can't say I've ever heard someone who worked in the engine plant describe the steps of engine assembly for a 351C and, for all I know, the rockers may have been installed and torqued according to spec at assembly, at which point everything was new and if a bolt reached torque before 1/4 turn or after 1 turn it's possible the lifter, pushrod or rocker was tossed in the "scrap bin" and replaced... can anyone say for sure? The only thing that CAN be said for certain is that the Shop Manual shows the procedure for installing rockers when servicing the engine and that's where we are...not on the assembly line.So what I’m hearing from those who say to make necessary adjustments rather than simply torquing each bolt the same is that on the ford assembly line they did the same thing suggested here and didn’t just torque down each bolt the same on the assembly line …yes???
Agree and this is my point.. I did some research and found that ford assembled these motors on the assembly line by simply tightening to spec.. nothing else no adjustments, no turning the motor to TDC etc nothing more than tightening the rockers down to spec… so if I’m running everything factory stock no mods etc bone stock and everything is factory stock !! why wouldn’t I do the same!! Lol ..
So I copied Fords way and she’s fine runs great. I put her back to together just like Ford did on the original Wngine assembly line and she’s fine..
Man!! How confusing opinions can be on how to do things…when I concoursed my 65 FB I always ran into the same things.. lots of bad suggestions and misdirections.. until I went directly to the source.. Ford!! Original materials etc.. I knew this was a weird senario.. and as an engineer it didn’t make sense to have to do anything to a stock setup except what Ford did oritingally to make her and I kinda trust Fords way vs others so I’ll stick with that.. thanks all good bye!!
yeah, I went to think there was some adjustments pre-adjustments. If it wasn’t for two flat metal meeting surface is just simply coming together, since that’s not the case, and these rockers are not adjustable and everything’s bone stock I’m gonna go with common sense to meeting surfaces torque it down make sure everything fits correctly and it’s done and I’m not saying that the engines were assembled on the assembly line. I already know they were preassembled, I’m saying how Ford assembled them, thanks to All! end of discussion, how many use common sense and FordI take that claim with a grain of salt. On the "assembly line", the engines were already assembled, painted and run. I can't say I've ever heard someone who worked in the engine plant describe the steps of engine assembly for a 351C and, for all I know, the rockers may have been installed and torqued according to spec at assembly, at which point everything was new and if a bolt reached torque before 1/4 turn or after 1 turn it's possible the lifter, pushrod or rocker was tossed in the "scrap bin" and replaced... can anyone say for sure? The only thing that CAN be said for certain is that the Shop Manual shows the procedure for installing rockers when servicing the engine and that's where we are...not on the assembly line.
Wouldn't the proper assumption be that Ford didn't just torque them down? Then, the correct action would be do follow the accepted procedure to ensure the preload is to specification instead of "winging it"? Is there some underlying reason why you don't want to do it properly?Yeah always makes sense to double & triple check the correct way to do important things like this..
Also, If anyone can prove that Ford didn’t just torque down,, the non adjustable rockers n 1970 351c engines etc.. to spec.. LmK .. show me the proof, otherwise I believe everything will be fine here.
Everyone.. thanks for your input ..
