That's the one I have, works great. A word of warning. Forget the MT and AT labeling, it's a sure fire way to get the wrong starter. Use the SFD0001 for any 157 tooth MT or AT flywheel, including 5.0 V8 and used the SDF00012 for any 164 tooth MT or AT flywheel. I went through this when I ordered mine from DB. I ordered the SDF0012 when I swapped my C4 for a Toploader and it just spun with out engaging the flywheel. I spoke with DB and they set me straight and explained the differences. I'm using the SDF0001 in my 4 speed car
157 tooth flywheels have the ring gear set back about 3/8" while 164 tooth flywheels have the ring gear flush. Catalogs list the 164 tooth starter as manual versions and 157 tooth as automatic. It works if your automatic is 157 tooth and the manual works if you have the 11", 164 tooth flywheel. Double check before you order!
