Hello!
I have a 351c 2v currently running the stock cast iron intake and carb. When I install the Edelbrock Performer intake that I have I can never get the darn thing to seal without out a vacuum leak. No problem with the stock intake though which leads me to believe that the aluminum intake has warped, or the top of the heads have been milled, but how do I go about determining which one? Use a straight edge on the intake manifold to see if it sits flat?
In a few months I would like to install a Holley Sniper system but would like to go with a 4bbl system to replace my 2bbl carb so I need to get my intake problem figured out. If I determine that my Performer intake is in fact warped, I have my eye on on the Edelbrock Performer RPM Air Gap as it already has the intake plenum divider milled which would play nicer with the Sniper.
If my intake is NOT warped, how do I go about determining how much of my heads were milled to get my intake matched to it? I have read that sometimes the machinist will stamp how much he took off, but I don't recall ever seeing anything on the top of the heads.
Any help or advice is appreciated! Thank you!
