Huh....that is the big block sway bar ...
Maybe it is just me, but that looks just like the one I have on my car in the above picture....
Is it possible that the engine has to be absolutely and completely seated in order to get the oil filter in? Right now the tail is not 100% raised up and the toploader is on blocks, we have to pull it back out to get the header bolts in. The oil filter was hitting going in, but again, when you are hanging a large engine in the air, you are moving quickly and taking crap off to just get it seated......
I also have TCP motor mounts..not that I think that would make a difference....
Once the engine is seated in its final place, approximately how much clearance between the filter and bar would you say there is?
Thanks.
