I ordered a new brake switch from NPD and have it installed per the image. Has anyone else had this experience. I can only fit one of the nylon washers that are supposed to go on either side of the switch. If I install the second washer the cotter pin hole is obscured.
I also understand from a YouTube video that there should be a certain amount of push rod play around the shaft for the switch to work.
I’d appreciate any comments or suggestions. Image attached.
