I have a 65 mustang 289 C code that wont turn over. It has sat in garage for about five years. It the motor ran when I put it away.
There is a some leaked oil under the car but the oil level is full.
I changed the solenoid. No use.
What size socket is needed to turn the bottom pulley? What size socket is needed to remove plugs? If the engine is seized, should I squirt anything into the spark plug hole? Some say spray WD40. Others say some mixture of oil diesel fuel and who knows what.
I just want to get it cranking. If it will crank I know it will start.
