61 - 71 of 71 Posts
Discussion starter · #61 ·
Most folks don't have their own oxy-acetylene bottles and torch but if you have a propane torch tip you might try a bottle of Map gas to see if it will be hot enough to melt the bronze metal. You could try to heat it up and brush it off with a wire brush. It less destructive than trying to remove it with a grinder due to the tight crevices.
Also that corner is going to be rusted on the underside as well. It makes it a little trickier for a novice welder as you will blow lot of holes unless you are familiar with both the process and the machine.
No doubt. I may try to weld a reinforcement piece under the corner to form the ledge and the weld another identical piece on top of it. We’ll see. As for the brass I was also thinking of leaving it in tact and using epoxy weld to extend a section of steel over. By the way, can you recommend a good mig / gas welder that’s not too expensive ?
Discussion starter · #62 ·
That’s so funny. Didn’t you suggest I check out one of his YouTube vids a few weeks back ?. Anyway, I ended up emailing him and we’ve actually now spoken twice. Doug is a great guy and it’s been a good connection. He made some great suggestions about rebuilding the tops of my pillars and taking it in small sections in terms of fashioning the metal. I was telling him about VMF on Saturday (yesterday) and telling him how much it has helped me. I guess he must have joined. Cool, I’ll check out his post and jump in. Thanks Brian.
Discussion starter · #66 ·
Glen, a gas welder is the way to go. Check out the local classifieds in your area for a used Lincoln 180. Their 140 version might be ok too but my experience is only with a couple of 180's that I used.
so there is a used 220V Lincoln 175 for sale that looks like it’s in pretty good shape. $400. But I can buy a bran new Lincoln 135 for less. The 135 advertises thickness up to 3/16 Any thoughts. I’d have to convert to 220 for the used unit
With complete convertible body shells being sold they dont have that section of replacement sheet metal available?
Chris
Glen, I have no experience with the 170 so can't help you there. I think I remember a few forum users talking about an Eastwood 135 model that just so happens to be on-sale right now for $229. Eastwood 135 Amp MIG Welder
Or with cart for $326 Eastwood MIG Welder 135 Amp and Cart
Josh @Lizer has been using one of these. Perhaps he can offer his opinion on this particular model.
I've had my Mig 135 for about 12 years now. It looks like a direct copy of a Miller in every regard (same knobs, graphics, etc). It's been a really good welder for me, I use it a lot. I haven't had any issues with mine. I was happy enough with it that I bought Eastwood's plasma cutter too a year or two ago.
Reactions: Caper50
I've also had the MIG 135 from Eastwood for quite some time w/out any problems. Did my entire car and numerous odd jobs with it. No complaints.
Discussion starter · #71 ·
Thanks for that. Yes I’m leaning toward taking advantage of that sale and not having to patch in another 220 circuit. I was only wondering if the higher amperage of the 170 would come in handy for certain situations. But I don’t think there is any steel on a 66 mustang much thicker than 1/8 inch. The Lincoln 135 is rated for up to 3/16 which seems like plenty to me. Either way I’ll be starting from scratch with huge learning curve ahead.
61 - 71 of 71 Posts
