67 steering column rebuild help - please
8.5K views 11 replies 3 participants last post by  jerrys67
I am trying to rebuild my 67 steering column (non tilt). The top bearing is shot. What are my options? It seems the tilt bearings are available, the pre-67s are available. Are the 67s and 68 the same? I have the new wiring and turn signal parts. My steering shaft looks to be 2 parts welded together, is that normal? Can someone help tell me what parts I need for the bearing? It looks like bearing, sleeve, and spring?? I can find a 68 bearing, but I think they do not need the spring, and not sure it will fit. Any thoughts??
I have checked the 1968 Edition of the 1965-68 Parts & Accy Catalog, the 1975 Final Issue of the 1965-72 Parts & Accy Catalog, and the 1967 Only Edition of the Parts & Accy Book. Looks like you, as well as other '67 owners are "lucky" enough to have had one of two different size bearings; both different than 65-66 and 68 Mustangs. One is Part # C4OZ-3517-A which is listed as 1-5/16 OD, and is the same as for 1965-67 Fairlanes and Falcons with Manual Steering. The other is Part # C3DZ-3517-A,and is listed as 1.44" OD, and shown for 1967 with Fixed Column only. The Upper Bearing Sleeve appears to be the same for all 1965-67 Mustangs, and is Part # B1AZ-3518-A (0.98 ID, 0.5 thick), later replaced by Part # C1SZ-3518-B (1.04 ID, 0.352 thick). And the spring (which yes you should have) is Part # C6OZ-3520-A for 1967-68 289's, and C7OZ-3520-A for 1967-68 390's (this spring is also the same as used on 1967 Fairlanes and Falcons.
As far as your steering shaft, I personally have not seen one that appears that it was two pieces welded together. Of course a lot depends on how you plan to drive it, but if it were me, and the weld is that readily apparent, I'd be looking for another.
Hope this helps,
Bob
Everything I see shows the C3DZ-3517-A as a bearing for the 65 and 66, but it looks like what I have. As best I can measure that seems the right size, if anything a little bit smaller OD, but it is hard to measure for sure. Has anyone tried this part in a 67 fixed column? They are rather cheap, so I might try it just to see what happens.
I have not removed it, it is pressed in as best I can tell (could also just be held in place with 50 year old grease). I was worried about trying to get it out and further damaging what I have if I could not find a replacement. The column ID seems to be 1.5. The column collar makes it hard to measure exactly. Thanks for all your help. If a 66 bearing would work, I think that would help a lot of folks with fixed columns.
