I would first check the fuse in the system to make sure its not blown. Second I would check to make sure you are getting 12V to the on/off switch. Then I would check the turn signal wand-the two position button can go bad-also the wires that go to the wand are very small gauge and snake through the column and can get broken easily. I would unplug the turn signal wand and check its function with a multimeter by checking the button in both positions. Then I would put a vacuum tester on the servo(bellows) and make sure it holds vacuum. Also, make sure the control box underhood is getting vacuum to port marked "V" (I think) and out the bellows/servo marked "S". Also, there is a holding relay out on the control box under hood. Sometimes these relays get water inside and rust and wont move-you can take it apart or put 12V to it and you will hear it click if it works-basically the same as tilt relay. Finally, I would crack open the control box under hood. The perfect circle units have points than can get corroded, but for the most part these isn't any electronics in these-maybe a few resistors, I think. If the control box has had water inside you should look for another unit-I think all ford/lincoln perfect circle/dana units were the same 68-9. These units were also used by other manufacturers but the wiring may be different. You could also look at the cutoff wiring that jumpers into the brake light switch-these often get broken or rerouted, but usually only prevent you from shutting off the system. Good luck.
