Accelerator pedal loose...need to re-install
5.7K views 13 replies 6 participants last post by  Horsehead
My accelerator pedal became loose and was about to fall off while I was driving. I think at some point the bolt came off cause all I had was the screw when I took the pedal off. Do I just stick a bolt on the back of it and I'm good to go or are there any washers or anything else needed??
Pictures attached....
On a 65/66, there is a little sheet metal clip that the screw goes into through the other side of the pedal. I wish I can try and take a picture of it for you. Both of my cars have it. Without it, the pedal will wobble as it loosens. I dont know how to attach pictures, so you will have to PM me with your email address. I will go take a pic now if I can from an installed angle. I will let you know how it goes.
