Does anyone have the plans a member(Buening, I think?) made of some adjustable motor mounts? I'm looking for plans for a 1"drop set in PDF format if anybody has them. Thanks!
Well, I have this file, but my buddies plasma cutter wont run this type of file. He says he can use a PDF file though, and I saw somewhere somebody had it saved in that format. Thanks though.Hi
Hope this is what you are searching for.
I just converted the 1" Drop Height.Well, I have this file, but my buddies plasma cutter wont run this type of file. He says he can use a PDF file though, and I saw somewhere somebody had it saved in that format. Thanks though.
If you don't have the ability to cut the pieces yourself and must take the drawings to a machine shop I think you would be better off buying the mounts from Ron Morris. I can't see a machine shop charging a small fee to do all of that cutting for you, I think it would be a large fee.Anyone know of ones that you can give to a machine shop to have them make it? I got 3 different ones years ago from here, they had a scale marker (1" size compare in the PDF). The ones I'm seeing here, don't have a size reference.
Those kits are $235.00, I don't know how much the plate steel is but there's a local shop with a cutting bed, they didn't charge much last time, but that was years ago.If you don't have the ability to cut the pieces yourself and must take the drawings to a machine shop I think you would be better off buying the mounts from Ron Morris. I can't see a machine shop charging a small fee to do all of that cutting for you, I think it would be a large fee.
Thanks! Looks like the same basic design. Did you do a 1" drop and if so, what difference did it make?I just converted the 1" Drop Height.
Here it's the .pdf file.
Let me know if it's ok
Hello.Thanks! Looks like the same basic design. Did you do a 1" drop and if so, what difference did it make?
I can certainly understand being busy with the kids activities and year around sports. My does time fly my two are 19 and 14, enjoy it while they are young before you know it they'll be wanting to do there own things. Good luck on your new partnership.Well I haven't driven the mach in 3 years, if that tells you anything LOL. I have a whole bench of parts that I've been meaning to put on the car (including a new set of 11R heads).....but alas they sit and collect dust. The kids are 7 and 5 now and in multiple sports year-round, so its work/sports/sleep on repeat. I'm also about to become a partner in the engineering company I've worked for since college, so that extra responsibility also takes away from free time. Busy busy, but very good!
