I'm curious if anyone on here is using a 4" diameter drive shaft? I can get a 4" diameter steel Dynotech driveshaft for a song ($40 or so) and will be the perfect length for my T56 conversion. I will check the clearance with my stock 3" driveshaft to my Magnaflow stainless 2.5" exhaust/xpipe, but are there any other concerns I should be aware of?? I will check the yokes to see if they are the same size or if a conversion u-joint will be needed.
The extra diameter will keep the driveshaft fairly rigid during high rpm spins and should keep the vibration to a minimum. It's most likely way overkill, but the price is right. I'm looking for any input you may have, good or bad
