Anyone running a "X brace"
6.4K views 12 replies 10 participants last post by  palerider
Anyone running a x-brace in their car, did you notice any change in your car.
I don't want to install a roll bar, would this help, I do have frame connectors already.
like this
1964-70 Maier X-Brace (Hardtop)
I have TCP subframe connectors with the TCP x-brace. The car feels very solid and I haven't noticed any creaking from the body when I hit bumps in the road so I'm sure it is doing some good. I haven't tried driving the car without it since I haven't really ever felt like removing it and going on a drive for comparison.
Save your money. You don't say what year your car is (another of my pet peeves about signatures), but if it's a '65-67 install BOTH front torque boxes and convertible inner rockers. That will do more for chassis stiffness than an X-brace OR subframe connectors.
No need to apologize for it being a '68.....even if '66's are much better looking... :yoho:
The solid roof, wide sail panels, and deep floor provide an extremely rigid structure for resisting stresses of up and down and side-to-side motion. Where the weak point is, is torsional (twisting) motion which subframe connectors and x-frame doing do diddly squat to prevent. Short of a full cage there isn't a ton of things you can do, other than maybe a convertible seat pan. If you have less than 400hp going to the rear wheels are aren't running wide slicks I wouldn't worry anyway.
I made my own connectors and used a TCP X-brace to connect them. Basically because I liked the idea of the X-brace more than anything. I also installed an 8 point roll cage so even if the x-brace did anything particularly helpful, the cage probably overrode it. My roll cage is also in my car just because I wanted them and no other really good reason. It did stiffen the heck out of the chassis though.
Thanks for the replies.
Car is mostly street car, does make 500 plus rwhp, and does see slicks at the drag strip.
Think i will try the x brace, as roll bar just doesn't work for me.
It's nice to see support for our connector kits here. A pair of welded in subframe connectors and a bolt-in x-brace or center support will make a significant difference in the torsional rigidity of your Mustang. This will improve it's life expectancy in addition to providing a noticeable improvement in handling, even on a street car. It will make more of a difference than adding floor or rocker pieces from a convertible and will be easier to install. Adding the extra torque boxes definitely wouldn't hurt.
A roll bar will do even more and we encourage their installation; we like it when people are safe. However, we know that's not an option for every car.
These cars aren't necessarily 'flimsy' but I would venture a guess that the Focus has a more rigid chassis structure.
