Carb sizing
2K views 9 replies 7 participants last post by  Mach1NH
Hi,
Back to the 65 with the 5.0 roller motor. The car with driver weights 3020 lbs. The heads are Performer RPM, the cam is unknown but the lift is .528" or so, the converter is 3000rpm, intake is a dual plane design but I have an old 289 Torker ready.
With a 600 Holley (Vacuum) it runs has the following times:
60' = 1.785
330' = 5.045
1/8 = 7.838
1000 = 10.283
1/4 = 12.383
The carb sizing formula says it needs a 568 cfm carb.
But when I talk to other folks running similar cars, they are running 750 cfm, they think I'm nuts running a 600. This is a drag race only car.
So, what is the right size carb for this sort of car?
Regards, John
Top end RPMs have a great deal to do with carb sizing. A 750 isn't too big if you are running over 7,000 RPMs. I am running a 650 Speed Demon Double Pumper with my stick car, you might want to run a vacuum secondary carb with you slushbox. A 650 should get the big end a little sooner.
The improvement in carb and intake manifold design has made the "formula" obsolete for quite some time now relative to optimizing performance.
If all you're doing is picking a carb for a grocery getter, the formula will be adequate. But a modified/high performance engine will not realize it's peak potential with that method.
Here are a couple of links with good info:
http://carcraft.com/techarticles/56919/
http://www.pro-system.com/pjames011900.html
http://www.popularhotrodding.com/tech/0503phr_carburetor_tech_terminology/
I always had good luck with a modified 3310 Holley with the Torker and F4B manifolds and iron heads. What rear gear and tire radius are you running? Trans brake?
With the torker, I found the combination to be sensitive to the height/profile of the plenum divider, more so than to the thickness of the carb spacer. Be sure to experiment.
Nice numbers for a stock suspension rig. Good show.
Pat
Hi,
The rear end ratio is 5-something, the tire is 26 inch, no trans-brake.
The motor "feels" done @6000+. It could be the dual plane manifold, or the carb.
I've got three different carbs available the 600 vac (actually 2), a 650 mech, and a 750 mech.
I've been considering a 4 hole 1 inch spacer, and maybe annular boosters for the 750.
In a fairly recent issue of Popular Hotrodding, they had a great article by David Vizard on this subject. To gloss over it quickly a point to concider is manifold design. When you have a dual plane manifold, basically you're dividing the carb in half and as a intake valve opens, it only has access to half the carb. With a single plane the intake valve has access to all four venturiis. Basically Dave Vizard said a dual plane manifold would like more carburation then a single plane. For what it's worth, I read an article several years ago about porting intake manifolds. The maniold they used was the old Torker with the twisted carb. What they found was that the old Torker didn't have enough port volume to match todays heads and would be a restriction.
If we're talking about the edelbrock torker II manifold here, EVERYTHING I'veread concerning that manifold is that it is junk. What tranny are you running with those gears? Thats some crazy gear you got goin there its not too much is it?
