dipstick tube install
4.6K views 7 replies 7 participants last post by  macstang
Well I'm now stuck! I have a 1969 351w I'm trying to put a dipstick tube into and it's stuck half way in. I used an open ended wrench that just fit around the tube and laid it on the flare at the bottom. Using the wrench as a taping surface I pounded away. Any suggestions as to were to go from here. Hitting it any harder will ripe the flare off!
These chrome aftermarket dipstick's don't fit. I had to grind mine thinner quite a bit to fit
#7 · (Edited)
Went through something similar recently. Also started to do the box wrench strategy but got concerned the thing would be mangled before it seated so stopped and ordered a Lokar braided dipstick because at least it had more meat to work with on the base to press in. The box end technique worked but initially wasn't cooperating so nicely.
What eventually got it was supporting a section of the wrench handle on a nearby eng. block tab as I tapped the wrench handle with hammer. W/o that added support, the energy from hammer wasn't quite making it smack dab where it was needed.
Talk about such a simple thing adding drama due to various potential consequences. Course I used some oil on the end. The Lokar uses 2 o-rings. I removed the first one when it was looking like was hanging me up but in fact wasn't. It just took some effort to knock it in. I like how it mounts and looks better than original/repro. Wasn't cheap but beats alternative outcome of breaking aftermarket dipstick off in a freshly rebuilt/installed eng.
#8 · (Edited)
The last chrome oil dip stick I got was too big for the stock hole. Fortunately, I also was re-gasketing the timing cover and the oil pan so I had everything off. After mic'ing the dip stick tube I got the right sized drill and drilled out the hole in the timing cover. I didn't think I would be able to keep the tube perfectly round if I ground on it. It still bleeds oil out down at the bottom though.
