Erratic RPM on FiTech EFI dash
12K views 6 replies 4 participants last post by  qbui
I had this erratic RPM issue that was once in a while and since yesterday, it was constant for awhile and then go away and then come back.
Either while in park or driving, I can see the RPM jump from 1200 to 4000 then back then 5000 then back then 2000 then back. Sometimes I could hear the fuel rushing through the TB from within the car. I have a second tach that I installed before the FiTech and that one doesn't have erratic RPM while the FiTech is going bezerk. They are both connected to the same post on the coil.
What I've done to try to rid the erratic RPM.
• Sanded and clean all of the grounds to the engine and battery.
• Ran the lines from the FiTech to keyed and coil inside their own vacuum rubber hoses to try to eliminate any cross interference with any other lines.
• Reset the learning on the FiTech few times
• Asked FiTech before but they have no answer
• Enable data logging few times while this was going on but have not downloaded the info to send to FiTech
Any suggestions where to look for this erratic RPM?
Thanks!
When this is going on, sometimes I would hear the fuel gushing through the TB like it does at first startup. I normally don't hear the fuel going through the TB other than at first startup. Also the car would surge because of the RPM increase and the AFR jumps too. Don't notice any difference in cold or warm engine.
So it was bothering me and I just wanted to make sure there weren't any obvious vacuum leaks. Checked the hose for the ported vacuum advanced and looked fine. The hose for the PCV looked fine too. When I went to the passenger side and took the cap off for the manifold vacuum and noticed few drops of fuel dripped out but the cap looked fine. Then I took the cap for the other PCV port next to it and few drops of fuel dripped out and the cap looked fine too. Checked all the other hoses and they were still like new since I replaced them about 5 months ago when I installed the FiTech unit. Does it sound weird to have fuel coming out of these 2 ports?
Thanks!
Was on the phone with the FiTech tech this morning and we tried to adjust the system and get the IAC numbers to where it should be and would not budge. Cody, the tech and probably owner said I have a small leak somewhere and to cap off all of the ports on the FiTech unit to see if the numbers will react to the adjustments. I'll probably cap off the vacuum tree on the manifold for the brake booster and other items too to see if any of those are the culprit. Did act like a vacuum leak but I couldn't find it before but now I have a FiTech tech telling me the same thing so that's my next project, to check for vacuum leaks.
