Fan pulley; how many grooves for car with PS ?
3.5K views 11 replies 8 participants last post by  Flade
65 Mustang with power steering; should the fan pulley have 1 groove or 2 ?
Our 65 has a single groove fan pulley. 1 belt goes around crank, fan pulley & alternator and 2nd belt goes around crank pulley and power steering pump pulley.
Someone told me if you have PS, your fan pulley should have 2 grooves. Is that true or false ?
Thanks-
Picture from a long time ago on my car. 3 years. Early Eaton pump but same idea.
As usual Chock is correct.
From the 66 Engine Assembly Manual
289 Engine with Power steering
Alt, Water Pump, and P/S are all 1 sheave (Groove)
Crank is 2 sheave
1st Belt goes between Alt, Crank inside Sheave, and Water pump
2nd belt goes between P/S pump and outr crank Sheave
The 2 Sheave Alt pulley is used with A/C to drive a higher output alternator
