In my 1971 Mustang I have the 9" with small bearings and a 31-spline axle. I used Strange's sealed bearings. They lasted about 12,000 miles, 3 years and about 30 AutoX events and 6 track days. I had this noise coming from the rear end and after further inspection the outer bearings were cracked at the housing and were wobbly. After some research I figured that the ideal setup is a large bearing housing with tapered bearings. Unfortunately they don't make tapered bearings for the small bearing axle. For now I will make sure to replace the bearings at the end of the season. For the long term I may look into a big bearing axle. The issue is that upgrading the housing also means replacing the brakes so it adds up quickly. Any thoughts or experience to share?
