hi guys,
thank you very much for all the valuable input.
Ears, the push on terminal is a very good idea. The problem is; I have two leads connected to the plus terminal. I am afraid, with a push-on terminal the second cable (connected with an eye crimp terminal) would not be securely pushed down.
You could clean up the threads enough to screw an extender on. Of course the push on terminal is easiest
Small Parts 370811HM303 18-8 Stainless Steel Male-Female Threaded Hex Standoff, 3/8" Hex Size, 1/2" Length, 10-32 Thread Size (Pack of 5): Amazon.com: Industrial & Scientific
a.co
Buy part #12216-9 WIRE, DISTRIBUTOR PRIMARY, SINGLE POINT DISTRIBUTOR for your classic vehicle from National Parts Depot. Free shipping on orders over $300, fast delivery & everyday low pricing! Order now!
www.npdlink.com
Thanks, JW67Conv. I have not seen an extender like that before. Good input I could use on another project.
You can try and fix it. If it's not reliable, you will have to replace it. The terminals are soft copper and easy to strip.
cougar70, you are correct, that is exactly my concern as well.
That peg is stripped, in other words the material that used to make up the thread is torn from it's base and cannot be pushed back in place. Thread chasing dies can be used to dig material out of thread root but cannot put material back up onto the crest where it is needed. You can however re-thread it to a smaller size (metric if needed) but you'd be left with a smaller and weaker peg. Care would also need to taken so as to not rip the peg loose from it's base. If it was the last coil of it's kind and made of pure onobtanium I could fix it for you but you would not like the cost. Just buy a push on connector for it, then put the set away as a spare. Now don't screw up the new coil you are about to purchase.
I am with Pittbull on this, cutting a smaller thread will weaken the already small peg.
I'm going out on a limb here, there is not enough clearance on the coil to run the die down.
In the big picture, coils are cheap. Buy another, consider it the cost of education.
Asm109 is correct, the cutting die I have, is to big.
I found Time-Sert bushings, I will try it this way and let you know how it turns out.
This turned out more into a science project, just to see if it works.
I have a second coil, which I am running on the car now. So this one would be the spare for the trunk.
If it does not work out, I will just get a second coil as a spare. They do not cost an arm and a leg, even here in Europe and it is not worth while getting stranded on the side of the road 😉
Again, you guys rock 🤘. Thank you very much for the help.
