So this is my plan for replacing my 4100 with an Edelbrock 1406 carb:
Factory 4-hole cast iron manifold. C4 trans.
1) Replace factory aluminum spacer with 1" phenolic
2) Use an adapter in the 1406's rear port for PCV.
3) Plug the front PCV vacuum port on the 1406
4) Move the coil.
5) Run rubber fuel line between the factory engine hard line and a banjo fitting on the back of the 1406 with an in-line fuel filter.
6) Modify throttle push rod for ball-joint type of throttle fitting.
7) Source electric choke 12V from Pertronix Igniter switched 12V.
8) Pop on the the factory air cleaner.
9) Fire it up.
Does that about cover it? Now for some questions:
1) Where should I relocate the coil to from the top of the intake manifold? I've seen pictures of the coil mounted to the front of the passenger head but can't tell how that's done.
2) Do you guys make a custom hard line that brings fuel to the back of the carb instead of using rubber fuel line?
EDIT: Found this http://www.summitracing.com/parts/sum-g1532/media/images
3) Will attaching the choke to the Pertronix 12V cause any issues?
4) Is the port on the back of the 1406 adequate for PCV use? (I feel that tapping a port into a phenolic spacer might be a less robust solution).
EDIT: Just found this on the Edelbrock web site:
Q: Can I run my PCV line to the rear of the carburetor?
A: We do not recommend routing the PCV line to the rear of the carburetor. We recommend that the PCV line go to the front, if you have power brakes, they go to the rear.
Now, despite that, has anybody had problems using the rear port for the PCV?
5) What fuel filter is recommended? It would be nice to pick up a filter at NAPA instead of ordering an Edelbrock brand filter.
6) Will there be any vacuum leak issues with the 1406-to-phenolic-spacer-to-factory 4 hole intake?
Thanks!
- Alex O.
4) Move the coil.
9) Fire it up.
Thanks!
- Alex O.
