41 - 44 of 44 Posts
The bearings we use are rated at 32,000lbs. We've never had one fail or had a return from a customer.
For the 65-66 cars, we use a 1 3/8" hole saw to enlarge the opening of the arm for the sleeve. You need to be a good welder but I would not consider this a difficult project.
For the 67-73 cars, the sleeve is a direct replacement for the 1 7/16" bushing. We spot weld them in place to make sure they stay put.
DIY Lower Control Arm Bearing Kit (1965-1973) - Opentracker Racing Products
We also have a kit with the lower arm bracing
DIY Roller Lower Control Arm Kit with bracing - Opentracker Racing Products
and another with the screw in ball joint
DIY Roller Lower Control Arm Kit with screw in ball joint - Opentracker Racing Products
Discussion starter · #44 ·
If I had stock LCA's then I have no doubt that I could have handled the install myself in an afternoon. My LCA's being aftermarket is the only thing that caused my need to get clever. Not at all due to John's kit or assistance along the way.
In the end I am really happy with how they came out. And really looking forward to trying them out. Now I just need my new shock bearings and spacers from AFCO to show up and I will be in business.
41 - 44 of 44 Posts
