Outer Shock Tower Replacement
4.6K views 31 replies 12 participants last post by  wicked93gs
I looked at those too. In the end I just painted my stockers but I did swap to the 71-73 bump stop. kip
Not sure why covering the springs with stock replacements is a concern. Unless you’re constantly putting your car on stands and taking the wheels off, nobody will ever see the shocks and springs.
Put a bumpstop on the shaft of your coilover and ditch the whole outer tower.
You can't see any of it other than the LCA with the tire on.
#8 · (Edited)
#29 ·
If the top or bottom of the shock can be unthreaded to the shaft diameter then installing the bump stops is DYI friendly. Otherwise the shock has to be completely disassembled to install. My front non-adjustable Bilstein shocks cannot have the bump stops installed without the shock being disassembled from what I see, but I was able to remove and cut down the bump stops on the rear Bilstein double adjustable shocks myself relatively easy.
#30 ·
???Stat?????
I had no issues installing the bump stops on my non--adjustable ones. Remove the tension from the spring, slide the spring hat off, break the jam nut on the upper rod end bearing loose and unscrew them. Install bump stop and reassembled.
#32 ·
Theoretically speaking...even if you couldn't remove the end, you could cut the bumpstops in half with a thin blade(bandsaw, hacksaw, whatever) and slip them around the shaft and screw them back together afterward, they would still function as bumpstops...it would even expand the number of things you could use as bumpstops, IE something like this:
