I'm overwhelmed by the replies. Good stuff for sure! Concatenated email for all the replies. If I overlooked your comment, my apologies.
Palerider -
I’d say get a new radiator. Check/change thermostat. make sure fan is 1/2 into shroud. You can get aftermarket shroud from Jegs or summit. Let run and ensure circulating.
Ordering the 192 thermostat from the link that subpar63 gave me. Thanks for the link!
GradyStang - To the OP, are you sure that it's coolant that's steaming and coming out of the hood? Not trying to say necessarily that it 100% isn't, that being said it could be oil or other engine fluids that are on something hot like the intake, headers or exhaust and so forth. An electric fan is attached to the radiator either with ties, clamps or some sort of mounting system and typically has a small relay next to, or close to your starter solenoid. No need to wire it underneath the dash where the fuse panel is under there, it runs off it's own relay and has typically an inline fuse holder next to it that you can check as well. I personally like the electric fans because you can wire them how you want in that, depending on the relay, you can have them turn on and off at a set temperature, or adjust the preset temperature to whatever you want, as well as you can add an override or manual switch inside the car so that you can turn it on whenever you want it to. I think the easiest, although the most boring route, would be to sit and wait for the car to run for the 30-40 minutes or whatever it takes for it to overheat, and monitor what happens and from where with your IR temp gun. Or go for a 20-30 minute cruise, bring the car home and sit with it idling to see what happens.
Yes, 100% sure. I can open the hood and see the coolant/steam coming from the overflow tube. Thanks for the additional information on how the electric fan is wired and operates. I was working I would have to possibly change the entire wiring harness for additional electrical needs.
Scott65Coupe - I agree with the other 99% - get the rad flushed.
Hoping to get this done this week. Currently looking for a shop.
CJM68GT390 -
Lots of good advice. And your response shows your willingness to learn - great.
Here's my little advice: do the meat thermometer in the radiator first. It will tell you what temperature your thermostat is opening and how hot your engine is really getting. Then check your timing and determine if you need a turn-up, both problems can lead to overheating. A little diagnostic work before staring the part-replacement efforts is always a good idea. One problem with overheating issues is determining whether it's an engine problem (bad head gasket, poor ignition, burnt value, etc) or a cooling problem (clogged radiator, worn pump, inadequate fan, etc).
And yes, get the FACTORY shop manual. I also recommend the electrical assembly manual as it has lots of exploded views with mounting hardware.
Keep us up to date, ask questions, and we'll do our best to help. Good luck.
Will do the meat thermometer after the rad flush. Stupid question - how do I know when the thermostat opens up? I see flow in the radiator? If the cap is off and therefore not pressurizing, does that cause anything I need to account for?
Thanks all!
