Rear main seals for 5.0HO. Refresh my memory!
1.5K views 21 replies 9 participants last post by  Dunk67
Hi gents,
I am about to start assembling a 347 based on an early 90's 5.0HO, and frankly, I don't remember the last time I did a rear main seal (probably when I assembled the current 5.0 that's in it).
Based on my quick search, I guess I am looking for a 1 piece seal, but seems to be conflicting if I should bang it in, or install it and then torque the cap (I am assuming the latter, since it's still an option for me?).
Any brand preference? Obviously, I'd like to only do this job once. :rolleyes:
Teflon? I hear they are finicky?
Dry vs thin layer of RTV (will this be an unsolvable debate)? I'm leaning away from a thin layer of RTV in case it needs to be swapped out again in the future. Dabs of RTV on the corner of the main cap?
Thanks all!
I always did the install the seal and torque the main cap and it always seems to seep. I used the Motorcraft seal. I’d be curious as well to hear any success stories.
Thanks guys. Now are you talking 1 piece or 2 piece seal? I assume I need the 1 piece. I also assume you guys are using a 2 piece?
I can't seem to find anything on the Felpro site (in fact, it says No Parts, so I assume website error at the moment). Rockauto shows the PTFE/Teflon one, but no Viton.
Although Summit shows FEL-2922RS which they do label as Fluoroelastomer.
But yes, has anyone used the 1 piece?
Thanks!
Thanks!
I was referring to the 1 piece 80's 90's 5.0 rear main seal. I unfortunately have had the engine apart several times. What I read and followed was installing the seal then installing the rear main cap. Something was always seeping at the oil pan rear main area. When I replaced the Boss 302 pan I had with a racing pan with the engine still in the car, the seep became a leak. So, has it always been the pan or the seal? I have learned that exactly following the instructions on head gasket torque specifications included with the gaskets leads to no milk shakes in the oil as opposed to following the 60 year old shop manual.
I'd say follow the directions regardless of what seal you choose!
No RTV, it can actually cause the seal to come out. I went against my own advice on a 6BT Cummins with a 2400 series Allison trans. as the aluminum housing was slightly damaged. Next day it spit the seal out and I was redoing it. Very unpleasant.
I used a Ford seal and the OTC install tool on both late model 302 and 4.0 V6 which have similar one piece seals. Heard too much about leaks and correct install depth to chance it. Install tool is used after main cap is torqued, seal installed dry (no RTV or other sealant, wipe oil on the sealing surface if using a normal "rubber" seal like Ford part).
Thanks guys, I ordered the 2922RS (before your post, Bart). Patrick, do you happen to remember the exact instructions on the package (Since mine won't be here for a few days).
I just want to know if I can install the main caps, or if the instructions talk about installing the main caps first, then banging it home.
Thanks again!
I'm pretty sure those instructions are most likely written for an engine that is already together and you are just replacing the seal. I have read posts from "Woody" the guy that builds all the stroker motors that everyone always talks about...can't think of his company rn. Anyway, he says he installs the seals on new builds onto the crankshaft prior to installing the cap. I wouldn't be afraid to follow his guidance based on the number SBF engines he builds.
www.fordstrokers.com
Also, he hosts another site/page that requires a subscription that has dozens of videos he has made covering a lot of build details specific to SBF, OEM blocks, aftermarket blocks and heads, etc. A one month membership is under $20, but well worth the amount of information that is available, including rear main seal installation tips. There is also a forum on the site where you can ask questions and he’ll respond, but he’s fairly active on Corral.
