I’m using 1990 Fox body seats and installed seat heaters. So I need to run wires for the heaters and the lumbar support.
Would you run those through the channel above the rocker (and drill holes though the rocker and side of the floor to feed them to the seats) or under the carpet?
If under the carpet, how you you keep them from moving around? I’ve got lizard skin on the floor, so I don’t think tape will hold. I could probably use some small wire clamps and rivet those to the floor…just not sure what’s best.
