The Problem
The engine is idling very rich. When attempting to adjust the fuel idle mixture screws, there is really no impact. I can screw them all the way in (lean) and the engine continues to run. Adjusting them out just makes it burn more rich.
The Research
So, doing some research, I set my idle adjustment screw to get the engine to idle as low as it will go and then pull the carb to look (from underneath) at the relative position of the primary butterfly valves to the transition slots (located in the Venturi). The valves are clearly open too far, bypassing the transition slots. See picture.
Many posts on the web and even 2 books that I purchased on Holley carbs all mention a method for fixing this, especially when a performance cam has been installed resulting in low vacuum pressure. All suggest drilling small holes into the primary butterfly valves! After the holes are drilled, I should be able to adjust the idle lower which should result in the butterflies no longer opening past the transition slots. Then, in theory, the idle mixture screws will work again and I can lean the mixture out.
This sounds drastic. Is this common practice?
Should I check anything else before making this move?
The Engine
Newly rebuilt 67 390 with the following (according to my build sheet from Southern Automotive in GA);
- stock crankshaft
- stock 390 GT heads, fully polished and ported
- Edlebrock performer RPM hydraulic flat tappet cam #7106
- stock cast iron intake manifold, port matched to heads
- stock Holley 4150 carb
- compression is 10.2 to 1
At idle, I am getting manifold vacuum around 6inHg.
Thanks as always,
Dcubedus
The Research
The Engine
- stock crankshaft
Thanks as always,
Dcubedus
