Hi Folks - '69 302 coupe. Recently changed plugs, wires, points, condenser, rotor and distributor cap. This was only because the plugs needed to be changed due to running rich and I figured I would just do a tune up. All ran fine for a few days and then died. I changed the cap, rotor and condenser again along with the coil just in case. Still dead (car will crank but not fire). Unplug the wire from the coil to the center of the cap. I get spark from the coil to ground but no spark at the plugs. I bypassed the red wire to the coil and the wire to the starter solenoid to make sure the problem did not lie there. Still the same result. Points are sparking w/ cap removed and distributor turning. After the tune up I did notice that the turn signals in both directions would blink erratically when the car was running but blinked fine when the engine was off. Any ideas why I would have spark coming to the distributor but not to the plugs? Thanks!
