hey all
have my T10 tranny at the shop for some work and was going to clean up the shifter. i came across a couple things that concern me, these all revolve around the bottom end of the shifter, here goes in no particular order:
my shifter boot had a tear in it. i have a new one. how do you get it onto the lever? over the reverse "T" at the handle OR over the mounting bracket on the bottom?
there looks to be 2 little "plungers" one on each side of the shifter lever at the bottom. only one of those plungers has a spring behind it. should there be a spring behind each plunger? perhaps somebody lost one? any ideas where to get these springs?
in the bottom of the handle or lever there are the 2 mounting bolts that mount the lever to the tranny. one of the two holes has what looks to be a rubber bushing in it. the other hole has nothing in it. i think i may be missing it and needing that rubber bushing? any ideas where to get these?
thx a lot!
kent
thx a lot!
kent
