She took her first ride on the lift today because I did a little exhaust work - more on that in another thread, three steps forward, two backward....lol. Some folks asked about underside access on the scissor lift so I took a bunch of pictures. According to that five volume stack of shop manuals I picked up to go with the car, the lift points are on the front frame rails right by the torque boxes and on the rear frame rails just ahead of the leaf spring shackles.
The pictures tell the story. To achieve proper lift pad placement I used crossbars and various lift pads. I ended up with the bars placed laterally at the far ends of the platforms to hit the correct lift points. I used a taller lift pad to hit the rear frame. This keeps the car level and also ended up giving me some extra room.....If you wanted, you could fabricate some taller custom riser pads with enough height to improve access.
For my muffler work, I just cleared the rear crossbar and was able work around it. I don't see why you couldn't do full exhaust work with this setup. The entire suspension is accessible. The only limitation that would affect me would be full transmission access. You can get to most of it and do plenty, but that cross bar goes right under it.
