this is my sound gaol for my 68 with a 302
I want to know if a cam is what makes this car sound like its barley catching and running...
I have a 302, full exhaust and a Holley (might be a 650)...but I need to swap the mufflers to the Magnaflow.
this is VMF, so low probability of getting theory on here...
my theory, lower compression, low initial timing, combined with a really lean idle results in a VERY slow burn rate.
a slow burn rate combined with opening the exhaust earlier results in the explosion popping out the exhaust because it's so late.
high compression, more initial timing, a slightly richer mixture will burn off faster and not produce quite the crack out the exhaust when that valve opens well before BDC.
I would be surprised if that 302 with it's Performer RPM kit has any significant compression in it.
here is dull and blaty…. 244 @ .050 exhaust lobe with a 1.7 rocker. 9.3 compression.
https://youtu.be/FvrOUYh2zV8
CRAZINESS on not strapping that thing down!Not to hijack your thread, but just ran across this video last night (speaking of engine sounds...wait for it at 1:00 and 1:30. That's a sound I'd like to go for)
https://www.youtube.com/watch?v=tdPfQ1HiiTE
I can't believe he didn't strap the car down while it was on the dyno.
