I’m nearly ready to fire up the new build and need to top it off with a carb. Since Holley is running a special now is the time. By preference alone I favor a 650cfm, vacuum secondary with adjustable air bleeds. Doesn’t matter much to me if it has an air horn/choke—I can do without. I also planned to keep the PCV system & power brakes so I need vacuum ports.
What I’m finding is Holley has no such beast unless I run a 750cfm which seems too much for a street 331 stroker. However, Quickfuel & Brawler do, but not sure how good of a carb they are in comparison—I only want to do this once.
Whatever I pick will be dyno tuned (w/wideband) which is why I favor the adjustable airbleeds, otherwise I’d probable just go w/a Holley Ulta 670 SA.
Here’s my initial thoughts;
331 Stroker, AFR185 Renegade, port matched RPM AirGap, 10.2:1 w/Mahle flat tops, Howard’s roller cam 278/286, @ .050: 225/233, Lift: .560/.565, LSA/ICL: 112/108, FPA headers w/2.5“ dual exh all paired to a 4R70W w/a stall assumed to be around 2800rpm and 3.55 out back in the rearend. Im expecting the cam to perform up to 6500rpm. I’d consider the ‘68 Coupe somewhat light with me & fueled up around 3400lbs.
What say you guys on the above? What would you pick; vacuum secondary or mechanical.
- HOLLEY ALUMINUM STREET HP CARBURETOR 750 CFM - 4150 - Vacuum Secondaries - adj air bleeds. This seems a little big for my application and dont want to hurt the street manners, air speed or furl atomization. I like this one ☝. Seems to me air speed past the secondary is important to keep up, but how much of a difference is there when you can change springs.
- 650 CFM BRAWLER STREET CARBURETOR VACUUM SECONDARY 650 CFM - 4160 - Vacuum Secondaries - adj air bleeds & elect choke. This seems like just what i needed but I have zero experience with what I believe is a value line of carbs.
- Quickfuel HR-SERIES CARBURETOR 680CFM VS - 4150 - Vacuum Secondaries - adj air bleeds & elect choke. Same as the brawler, but wondering which is better between the two.
- HOLLEY ALUMINUM STREET HP CARBURETOR 650 CFM - 4150 - Mechanical Secondaries - adj air bleeds, no choke. Based on size alone and my experience with Holley, this is my preference, but concerned this paired with an automatic may be a bad choice. I’ve read plenty of threads indicating a DP is fine w/an auto if tuned, which it will be.
