I'm in the process of dropping in a Ford Racing 302 into my 66 coupe. Because the new motor is internally balanced, I've needed to install a neutral balance flexplate. I have bolted the new flexplate to the crank, then bolted the torque converter to the flex plate. When I tried to marry the block to the bellhousing, the nuts from the torque converter on the backside of the flexplate hit the aluminum block plate, preventing the bellhousing to mate with the block. :shrug:
I've got the load spacer between the flexplate and the bolt heads, but is there another spacer that should go between the flexplate and the crankshaft to create a gap for the torque converter bolts and nuts? There wasn't one on my old 302 and 50oz balanced flexplate.
Thanks in advance
Thanks in advance
