I know you probably thought my tranny stories were behind me. But my newly sealed tranny has been leaking since the day I put it back in. This is a strange leak though. The bellhousing and pan are dry (more or less). And I can drive it around, let it run, etc, and it doesn't leak. But come morning, there's a pool of red under the car. And I'm talking a big pool. Prolly 2 ft in diameter. Come back the next day, and it's 3ft in diameter. I've been hoping it's just the overflow valve pissing out what it doesn't want. I checked the fluid level, and it's at a reasonable level when warm and in park. It's quite high when cold and not running. So I pull the car up on ramps, and notice the pan bolts are a little looser than I remember. So I give them a little nudge, clean the floor, and put her back in her stall. Next morning, pool of red. So last night, I started the car, backed it up, and let it run while I cleaned the mess off the floor. Pulled the car back into place, shut it off, and put it up on jackstands. I placed a drip pan under the tranny, and left it for the night. This morning there is no fluid in the drip pan.
So I'm starting to put it all together. It's not a pressure leak. Otherwise it would leak while idling, running, etc. But it only seems to leak after cooling down from an extended running cycle. The leaking area is around the pan. Definitely not related to the newly sealed front end.
I'm still hoping it's the overflow, but I don't really know the behavior of that feature. If I can't find the problem, I think I may replace the new pan gasket with another new one, add fluid more carefully so as not to overfill this time, and try again.
Whatcha think?
Whatcha think?
