I'm chasing down a drivetrain vibration that has been in my 64 after some major driveline repairs. When I got the car the U joint in the rear end was way to short and the previous owner had apparently centered it by eye or something and it had no vibrations at 70mph. When I was doing my driveline work I took the Ujoint to the parts house and got one that was a little bit longer where it goes into the yoke on the rear end. I've been battling this vibration now and had the driveshaft in and out several times and swore the new ujoint was a snug fit in the yoke but after having the shaft out again it appears there is some side to side movement. What I need to know is how tight should the Ujoint fit in to the yoke when moving trying to move it perpendicular to the driveshaft (Along the green line in the attached picture)
The unjoint measured around 3.24" long along the green line with my calipers. There is a little bump on each side of the yoke where the read arrow is pointed and I'm not sure if the ujoint cap is supposed to fit snuggly against this stop or if there is a little slop along here. I'm 99% sure the yoke is original, the driveshaft is original. The new driveline shop did find out that the driveshaft had .030" run out and was able to bend it back straight, then had to rebalance it so that might have taken care of my issues. I want to make sure the ujoint is correct at the rear end. Thanks
