Universal AC kit
1.3K views 12 replies 11 participants last post by  ibex 276
I’m thinking about putting AC in my 1965 ford mustang. I live in Louisiana where it’s incredibly hot and humid and driving during summer is miserable. I’m in college and cannot afford one of the nice aftermarket kits that are $1,000+. I found a universal AC kit on eBay with good reviews that’s under $600 and I was wondering what you guys opinions are on it. I’m okay with it being pretty custom and having to do fabricate some things up. I just don’t know anything about AC and want to be sure I’m not wasting money. My car does not have power steeringThis is the kit.
Having grown up on the Gulf coast I feel for you with no A/C.
There will be a lot of additional expense with this kit as you will need a compressor to engine mounting bracket and a pulley for the crankshaft. I'm sure you will find several other parts are needed. And then I assume you don't have the ability to install it yourself so you will be looking at a large labor bill. It could easily cost $2500 in the end.
I have a couple of 2 groove pulleys laying around so that’s not a problem. I was thinking of just fabricating my own mounting brackets like I did with my alternator. I also plan to do the complete install myself as I’ve done everything on the car. The engine is a 289 that I built myself to swap as it was originally a 6 cylinder so I do have some mechanical knowledge.
My suggestion is to buy an original ford underpass unit. I had a vintage air underdash in my falcon and it tucked. I bought a used 65 falcon ford underdash take our and restored it. The ford unit works so much better and is a lot cheaper. I often times see complete underdash ford take out systems for $150-250 on market place.
Reactions: KYRobb and aboatguy
I have an after market AC out of a Mustang, albeit it was on the big side
I also have a Ford cast iron compressor bracket, that will fit a 289.
I am in the Dallas area, and shipping would not be bad
Underdash is $50 and compressor bracket is $30
Bob
All of the AC parts are available individually on CJ Pony parts. I'd recommend locating an OEM under dash unit that you can clean and recondition. make sure the motor works and that that its functional. I would disassemble, flush the core and install a new expansion valve. I'd then get the necessary brackets and get a new Sanden compressor. You will need a drier and condenser. There is a AC kit for the hoses or you can crimp your own. Obviously you need may need to upgrade your radiator and fan if they are not up to the task. Vacuume leak the system and charge with R-134. Plenty of videos and instructions online outlining the process.
I have a 1967 Coupe. Has a 1987 5.0. It is not show quality but I enjoy driving it. I wanted to AC it. I also did not want to spend 2K+ on a kit. I had put a Classic Auto air in a 1967 Camaro. I had also put AC in a 1958 F100 that had a 2010 Crown Vic 4.6. Using the CV compressor and then the other parts from Jeep Air. I saw an add from Qualy Air for a heat and cool kit for around $600. Just got it in. Actually, seems to work good. I don't know how long it will work but at the moment it is good. I have a Frankenstein serpentine belt system. I had to make my compressor mount. Moved my alternator from the right side to the left. I have power steering, so I had to make a mount for the alternator. I got the hoses crimped at a local Carquest. I had to buy a couple of hose fitting for the way I ran the hoses. 3 relays for the wiring. 2 cans of freon. A pressure switch because the one with the kit leaked. So it was less than $700 total for the AC
