Been reading alot on the forum about the issue I am currently having. Ive read that most causes are either do to drive shaft angle, drive shaft imbalance, improper u joints, and warn tail shaft bearings on transmissions.
The transmission is a wc t5 on back of a 351c and mated to a strange 9"
I have 2'' drop springs out back. The drive shaft angles visually dont look to me matching. Nor would I assume that they are seeing how none of the members i am using came along with one another.
The vibration on drive accurs on 5th gear around 1.5k rpm and is most notable on deceleration.
I wanted to get more familiar with my problem so I put the vehicles rear on stands, turned the vehicle on and took it up to 5th gear. The car begins to have some vibrations on 4th gear, but most notable on 5th with the car idling/coasting in gear at 700rpm. When I accelerate the vehicle up to 1.5-2k rpm the vehicle begins to vibrate.
I went under the vehicle, used a metal hammer to hold against the drive shaft, and it begins to make a ping noise, here and there. So the drive shaft is having some run off.
I dont have a degree finder, but have an idea on how to check.
The drive shaft, slip yoke, and rear ends I have not used before, they are new to my 351c and t5. The powertrain had no issue in my other vehicle i pulled it out of, But that was with the stock 8'' rear and stock drive shaft.
I plan to make a few calls tomorrow, to local shops to see if they can check my car out.
as of now I'm in a stuck position and quite not sure what steps to take next.
question: does any one know what the stock hp/ tq capacity is for the stock drive shafts? the drive shaft I am currently using is 2 inches short, and I am using a slip yoke that is slightly longer to compensate for the "slack". Maybe switching slip yokes, and drive shaft with the original set up would be fine? but will it hold?
upon inspection, I noticed that I can make the slip yoke move while its on the tail shaft of the trany. Maybe to much wear? Its a new slip yoke from summit, and its a ford unit. Not very much movement, but it is noticeable.
The drive shaft was balanced alone, not with the slip yoke.
any help would be great. Id appreciate any knowledge gained from previous experiences that where similar to this.
I kinda wish I went with a stock 9" set up, lets just say, strange engineering is lacking in their engineering, I had axle stud bolts rubing against break components that caused minor damage. Drive shaft came to short, workers didnt specify differences in their " bolt in rear ends" compared to factory units.
But thats kinda how life goes some times.
