I've decided that I have so much other work I want to do on my 68 that I'm going to put this engine back together with the 91 roller shortblock and AFR heads I picked up.
first off the seller stated that this engine had forged pistons installed and it was bored to a 306 ? can anyone tell what pistons these are ? Stock ? I'm skeptical now becasue the cylinder walls don't have a smooth lip at the very top of the cylinder in the block. Seems like if it were bored .30 over the entire cylinder bore would be fresh honed ?? You can see the lip in the pic below...
the seller of this engine said it has 9:1 compression with the 58cc AFR 185 heads. It also has 1.6 Twisted Wedge roller rockers, MSD Ultralite Distributor with super conductor wires. I pulled the Comp roller cam and it turned out to be an EFI blower grind so I guess I'll try to sell it and get something different. I want to pair this engine up with my AOD w/ 2,800 stall and 8.8 rear with 373 gears.
Would my dual plane Eldlbrock performer 289 intake and new Edelbrock 600 carb be any good for this applicatrion ? What about my Hooker comp long tubes in my car now ? Are the exhaust ports on AFR heads a different shape ? I also wonder if my longtubes would even work with the AOD. I have Hooker Shorty headers that came with the engine but wonder if they will hurt performance much over longtubes.
I really want big low end torque for driving around and an occasional long smoky burnout
