Wretched noise from new starter?
1.5K views 11 replies 8 participants last post by  67ranch
After spending the year building this with all new parts, crate motor/T5 and such, now finally able to turn it over for the first time and get this horrible sound ! Video with sound of it turning over. All fluids are in but no gas yes, just checking it that it would turn over fine.
** Does any one know what it could be? I've removed all belts so its not Alt, pwr Steering or water pump. It's a new starter from AZone , standard type for 60's mustangs. I pulled it to confirm the starter teeth and flywheel (which also is new, Ford Racing) and found no noticeable problems. The sound in the garage if way worse than it sounds on youtube but I think you get the point. The motor is a 5.0 from Blueprint. It seems to engage fine, no grinding sound just not familiar with what a bad starter would sound like.
Funny, When I installed my T5 w/ scattershieild I went and bought a "manual" starter. Turns out it needs an automatic starter. I forgot this when I replaced the starter last year...I will never forget again. Moral? I guess it depends which one you need.
